Flyfisher
- Norfolk, UK
As well as a mains gas boiler, we also have a few multifuel stoves, one of which is an 11kW boiler stove linked into the CH so the more wood we burn the less gas we use. But we're also fortunate to have plenty of free wood (if I ignore all the chainsawing and splitting involved!) and it often surprises visitors when they see how much wood we burn.
The thing to remember is that a, say, 8kW stove can only generate 8kW of heat if it burns enough wood, which means it's no good closing down the stove for a visually comforting slow burn and still expect 8kW of heat to be generated. Wood (of pretty much any type, hard or soft) will release about 4kWh of heat per kG. So if you want a stove to generate 8kW then you'll have to burn about 2Kg of wood. If you set the stove to burn it at a rate of 2kg/hour then you'll have a heat output of 8kWh. Now bear in mind that a typical gas boiler might be rated at 30kW and it means that you'd need to burn 15Kg of wood for the same amount of heat. Scale that up to the amount of time you need to generate that heat and the equivalent amount of wood become very large indeed. Suppose the CH is on for 4 hours per day, with a 30kW gas boiler that's 120kW/h of 'heat'. The same heat output from wood would mean buring through 30kg of wood in the same 4 hours.
As Scotty might say . . . 'ye canna change the laws of physics Cap'n'
