Hello all,
I'm new to this group and wondered if anyone has any experience with electric under floor heating.
We are renovating and extending a two bedroom 1870's farm workers cottage in the middle of nowhere in Lincolnshire. Therefore we are not on the natural gas network and are never likely to be. We have solar panels installed but at present can't benefit from storage batteries and charging during cheaper night tariffs, due to lack of WAN in our area. Our heating at the moment is radiators in most rooms supplied by a gas boiler running on LPG, however the previous owner set it up with 47kg cylinders that cost almost £100 each to replace and if we used this heating as normal people do it would cost around £400 per month! We also have a couple of log burners which we use in the evenings.
In the existing cottage the ceilings are very low, so unless we dig out the floors it would not be practical to install wet UFH. We could use this in the extension but the cost of an air source heat pump prohibits this as we are on a very tight budget and the only other option I can see is installing an LPG tank, however this would be an expensive install and running cost.
We came across a Norwegian electric system that looks like a solution, EP Warmfloor which is supposedly a low-energy, low-voltage, self-regulating underfloor heating system. We would be laying tiled floors which would act as large radiators. This would also get rid of radiators, which would be a benefit as the rooms are not huge. The purchase price of this system is not cheap but nor are the alternatives. I've read that the heating up phase is quite expensive but once temperature is reached it is economical.
We would normally like to keep the thermostat on about 18 deg.C, turning down to 15 over night. We would still use the log burners if we needed a boost. We are in the process of insulating the whole cottage, room by room, using breathable methods.
Has anyone had any experience with EP Warmfloor? or could anyone suggest any alternative ideas.
Thanking you in advance,
Diane
Diane
