fernicarry
- Argyllshire
Those off-peak cheap tariffs rely on you being able to store the cheap energy until you need it i.e. hot bricks inside a storage heater, hot water in a buffer tank, electrical batteries (EV's). There's quite a significant capital cost with that especially on the scale needed to make a meaningful dent in your space heating costs. In addition there will be a round trip cost that increases the effective rate. Converting electricity to heat is almost 100% efficient but putting it in a battery and getting it back out later definitely isn't. If you put all that together then your price per unit will be a lot less advantageous than first appears.
I'd much rather we have a more transparent and fairly priced energy market than all these games with weird tarriffs and windfall taxes and price capping so that we don't have to endure some of the most expensive rates in the world. I do however expect we'll continue to be scalped with a vague promise of it'll all be better at some unspecified time in the future once we have transitioned to net-nothing.
My own experience with storage heaters is from 1980's designs which frankly were rubbish as most of the heat had escaped by the following evening just when you needed it. Modern building standards might make them viable as a trickle of heat from the heater will be enough to counter the much lower heat loss from the building through the day. Since the OP is planning an extension then best approach would be to do all the disruptive stuff upgrading the building fabric at that time and design the heating system to match.
