Nigel Watts
- London N7
Flash is so unflattering. Here are some more pics in natural (too bright) light:
Hoorah!!Moo said:DUNNIT !!
Moo said:![]()
DUNNIT !!
I know what I did wrong - I clicked on the Img thingy and then pasted the link inside it.
Only a master woodworker could come out with a statement like that... :roll:biffvernon said:Does nobody else use planks supported by bricks?
Mine are mdf on bookcase strip screwed into the wall either side of the chimney, is that close enough?biffvernon said:Does nobody else use planks supported by bricks?
Nigel Watts said:what a wonderful set of rooms.
Moo said:Here's the link to the photos:
Feltwell said:Come on Moo, that's not really a period house. Where's the dodgy cracked L&P ceilings that have yet to be repaired? Where is the big patch of bare brickwork that has been awaiting plastering since 2003? Where are the sashes that are painted shut or need Geoff Capes to open? Where is the dodgy 60's gas fire? I couldn't even see any Artex, or woodchip..... :roll: It looks... - finished - that can't be right, surely??
In which case I bet you wished you'd used a few nails, screws, glue or pegs.MdB said:my bookshelf...is ...fixed together without any nails, screws, glue or pegs. It is currently flat packed and buried in a corner
Well, remember that several of us have done so. And I must say that I have rarely seen a more elegant and beautiful house.Moo said:Ah, but you should see it now.
