CatherineB
- Cambridge
Snapfish do lovely photobooks - the only I've seen, I have to admit. My bro and SIL did a great photobook of their wedding.
A recent consumer (Which?) report blew the gaffe on special data cables. They tested HDMI cables priced from somewhere around £3 (made from turnips) to £39 (made from genuine gold-plated Martian Kryptonite) and judged there to be no difference whatsoever in the quality of the signal.AMc said:As for speaker cable being expensive - I'm always horrified by what HiFi shops charge for simple cable £1 a metre upwards!
There will be some loss in quality compared with a CD or other high bandwidth source and potential for interference as the ones I've seen are using the same 2.4GHz band as WiFi, DECT phones, baby monitors etc. On the other hand the convenience is obvious- rechargeable batteries - particularly Enloop style ones that don't self discharge are a good solution and more cost effective than disposable batteries.downshifter said:Has anyone any views on wireless speakers? As I understand the system you wire up a small transmitter to the amp and off you go. The big drawbacks are expensive to buy and run (uses batteries or mains). Big advantages no unsightly cables to trip over or chase into walls and can move speakers to any room in the house or outside.
Back when DVD was just arriving in the UK I was really into home cinema (as opposed to now when I can't afford the toys so I've stopped lookingPenners said:A recent consumer (Which?) report blew the gaffe on special data cables. They tested HDMI cables priced from somewhere around £3 (made from turnips) to £39 (made from genuine gold-plated Martian Kryptonite) and judged there to be no difference whatsoever in the quality of the signal.
I wonder whether the same is true of your 5A TWE compared with over-priced hi-fi cable.
That's a highly informative treatise, thanks AMc.AMc said:The Logitech Squeezebox Radio
I recognise that scenario only too well. :lol: :lol: :lol:AMc said:Back when DVD was just arriving in the UK I was really into home cinema (as opposed to now when I can't afford the toys so I've stopped looking![]()
That's an interesting point, though it moves us into more complexity about what's going on inside these cables.AMc said:As I understand it the signal over HDMI cables (like cat5 and 6 data cabling) run at high frequencies and over 10m + runs they are more susceptible to interference and signal loss.
SCART is analogue....Penners said:Was he talking rubbish? If a digital signal can't be degraded, then I'd be interested to know what is causing this significant variation in picture quality.
Error correction is another whole 'layer' of digital communication systems. Are you familiar with http://en.wikipedia.org/wiki/OSI_model?AMc said:My understanding was that error correction information is sent as part of the digital data stream so that the decoder at the other end can work out if there was data missing and if so make an educated guess at what it should have been. Avoiding the sharp screeching noise and blocks in picture that you get when there is serious loss of signal. Only non real time packet based systems can ask for the data again if it didn't arrive intact.
Funny you shoudl say that.AMc said:God, how geeky have I become?![]()
We tend to assume, when thinking about wire, that when we apply a signal to one end of a wire, it arrives instantaneously at the other end of that wire, unaltered. If you've ever spent any time studying basic DC circuit theory, that's exactly the assumption you're accustomed to making. That assumption works pretty well if we're talking about low-frequency signals and modest distances, but wire and electricity behave in strange and counterintuitive ways over distance, and at high frequencies. Nothing in this universe--not even light--travels instantaneously from point to point, and when we apply a voltage to a wire, we start a wave of energy propagating down that wire which takes time to get where it's going, and which arrives in a different condition from that in which it left. This isn't important if you're turning on a reading lamp, but it's very important in high-speed digital signaling. There are a few considerations that start to cause real trouble:
1. Time: electricity doesn't travel instantaneously. It travels at something approaching the speed of light, and exactly how fast it travels depends upon the insulating material surrounding the wire. As the composition and density of that insulation changes from point to point along the wire, the speed of travel changes.
2. Resistance: electricity burns up in wire and turns into heat.
3. Skin effect: higher frequencies travel primarily on the outside of a wire, while lower frequencies use more of the wire's depth; this means that higher frequencies face more resistance, and are burned up more rapidly, than lower frequencies.
4. Capacitance: some of the energy of the signal gets stored in the wire by a principle known as "capacitance," rather than being delivered immediately to the destination. This smears out the signal relative to time, making changes in voltage appear less sudden at the far end of the wire than they were at the source. This phenomenon is frequency-dependent, with higher frequencies being more strongly affected.
5. Impedance: if the characteristic impedance of the cable doesn't match the impedance of the source and load circuits, the impedance mismatch will cause portions of the signal to be reflected back and forth in the cable. The same is true for variations in impedance from point to point within the cable.
6. Crosstalk: when signals are run in parallel over a distance, the signal in one wire will induce a similar signal in another, causing interference.
7. Inductance: just as capacitance smears out changes in voltage, inductance--the relationship between a current flow and an induced electromagnetic field around that flow--smears out changes in the rate of current flow over time.
