Cloudscape
- Mid-Wales
Carpet grippers and knees... yes that hurts.
What strangely doesn't hurt is trying to seal the end of a gushing 15mm pipe with your hand, after you thought the pipe was empty and you didn't have a bowl and you'd just used a pipe cutter. I had no idea I was gushing too, until the water stopped flowing. Cut pipe is razor sharp.
Another one I didn't think through was trying to loosen a frozen screw in a small metal block (big screwdriver in right hand, metal block in left). I sprayed WD40 on the screw and tried again. Very slippy stuff that WD40 and I nearly went right through my hand.
We live and learn... just not much. :wink:
