Schoolmarm
- edgworth, lancs
Aha, that is a bit clearer. :lol:
Maybe they have my dear but it doesn't make it right.Why is it no good? People have used that who have posted on here.
Spot on Paul.Experience comes with practice and advice so here goes for the next round
I don't think you have caused any offence. It is these sorts of conversations that raise the issues that amateurs like myself learn from. We can then pass on this knowledge when appropriate.OddJob said:Now,without wishing to cause offence to anyone one of the most common queries from my website is "How do I do this?",so I tell them,and the most common reply is,"But I've been told to do it this way!"
So my most common reply now is"If you already know why are you asking me?"
There are no experts in this game,only those who think they are.
I agree with you here, (apart from the lumps which I've never noticed) however, the question is "how quickly does it carbonate in the bag?" I do not know the answer to this (and would be interested in knowing it) blue circle give a lifetime of 3 months+ for their hydrate and I know that my local builders merchants gets a new pallet of hydrate every two weeks. I would therefore expect a bag of hydrate used within a month to have very similar active lime levels to that of putty. Any unused lime should be converted into putty of course for it to keep. Exactly the same process applies to NHL limes which will also carbonate in the bag. Some lime producers state that they will keep for 1 year in the bag so again the process must be slow.It doesn't matter how fresh hydrated lime is,as soon as it's hydrated it's exposed to air and carbonization begins and continues in the bag,that's what the little lumps are you find in every bag no matter how fresh.
Totally agree for most construction where everything is being kept in compression. It is where some of the structure could be in tension (such as long thin walls) that you have to worry. As we all know, cement will stick bricks together, so can be used to form structures which lime should not be.OddJob said:It's not true that lime mortars have no strength,remember,in masonry it's use to keep the bricks apart,not stick them together
That's the excuse used by people who have either never used lime or don't want to,they've only used cement and it works perfectly well for them and gets the job done.it always has been and all my mates in the trade do it that way as well and nothing has fallen down yet
Why?then we can make a judgement on that.
I'd recheck that if I were you,published where exactly?6:1:1 mixes are fine if you want a strong mix but 3:1 lime mixes with a couple of handfuls of cement are a bad idea as the cement clumps making the mix weaker than without it. How do I know this? well somebody has tested it and the results are published.
I thought I explained that,you obviously weren't paying attention.I agree with you here, (apart from the lumps which I've never noticed) however, the question is "how quickly does it carbonate in the bag?" I do not know the answer to this (and would be interested in knowing it) blue circle give a lifetime of 3 months+ for their hydrate and I know that my local builders merchants gets a new pallet of hydrate every two weeks. I would therefore expect a bag of hydrate used within a month to have very similar active lime levels to that of putty. Any unused lime should be converted into putty of course for it to keep. Exactly the same process applies to NHL limes which will also carbonate in the bag. Some lime producers state that they will keep for 1 year in the bag so again the process must be slow.
From this, I conclude that there is no technical reason not to use hydrate. In my very limited experience have also not noticed any difference in workability between hydrate and putty and as hydrate is cheaper, unless given a good reason not to, I will continue to use it. I very much welcome comments on this.
:lol:unused lime should be converted into putty of course for it to keep
Yes NHL 5 is stronger than NHL 2,eminently versus feebly hydraulic,with NHL 3.5 being moderately hydraulic.I, like most people here I guess, would have said that NHL 5 is stronger than NHL 2 (indeed the number refers to its compressive strength
So am ISchoolmarm said:I'm so glad you have joined. 8)
You want courses?Schoolmarm said:Do you ever do courses or instruction?
I do onsite training/instruction mainly for homeowners but builders as well,I don't have the premises for running courses sadly.Schoolmarm said:I am not a teacher really, but there are a few other members who are/were.
Gwan, gwan, gwan, you know you really want to! :wink:JoceAndChris said:But what I really want is just to give Gervase a big stash of cash to just come here and fix my house. Tired of broken down fingernails.
