LadyArowana
Or you could lay the bricks in a pretty pattern and not bother with the self levelling and bung a nice cheap mat/ rug on top. I know picture is a kitchen.....
plasticpigeon said:If it is not huge maybe mixing concrete in a plastic bath would remove the need for a mixer.
You're not alone, Feltwell!Feltwell said:My only note of caution is that in my limited experience of self-levelling compound, it's not that self-levelling and it's entirely possible to end up with an uneven floor unless you're quick and accurate with a trowel. Or maybe I just didn't mix it thinly enough!
Feltwell said:plasticpigeon said:If it is not huge maybe mixing concrete in a plastic bath would remove the need for a mixer.
It's bl@@dy hard work mixing any meaningful quantity of concrete by hand. Much, much easier with a mixer.
How about in the bath?plasticpigeon said:I have no space to keep a mixer overnight
Zebra said:Go away all of you.
plasticpigeon said:Agb's soultion sounds so obvious, now he has shared it.
Zebra said:Oh. Just read that properly. Can you do that? What do you mean, floor insulation boards? You insulate a floor with rigid foam like Kingspan, don't you? But under concrete, where the load is evenly spread.
