Gervase
- North London
if the difference between your floor and the outside ground is only six inches the you are gong to need some sort of french drain externally if you are to get rid of the damp,
However, 10 days is a very short space of time to observe the rise and fall of the damp - I would tell someone to wait for 10 weeks, particularly now autumn's here and condensation and humidity are skipping hand in hand to saturate everything.
I'm with you on wanting to preserve the place in as original a condition as possible, and I have a strong dislike of dry-lining; it's prescribed far more often than it's needed, and in the majority of cases, drainage is the answer. Our place has thick stone walls and is in a very damp part of the world - but we have cured any dampness by addressing the drainage and by keeping the heating on at a very low level from October through to March. It sounds bizarre, but we actually use less oil by doing that rather than have it come on twice a day at 'normal' levels.
If you want to go for panelling, what about lowering your switches to mount them on the panels - surely that would give you the required depth?
