Hello,
I have a 1600 century granite farm house in Guernsey which I have internally strip out and entirely exposed the walls and ceilings.
The walls are Guernsey granite with earthy, straw mortar. The floors are in one of the three ground floor rooms that have been stripped, hardcore and a thin hollow layer of concrete, and the other two a thick bed of sand with hefty joists and floor boards on top. The joists are rotting at the bottoms but still plenty of stong wood left.
The property appears to have had work done included some dry lining probably 40 or so years ago.
There is some wet rot around woodwork in or next to the granite walls, and at floor level. There is also death watch (is that how you spell it?)in some of the joists, lintels and beams but most appear still solid and salvageable.
I have sort initial advice of a local surveyor and a timber treatments and damp firm. An I have also spoken to a local chap who sells lime products and read a bit about the benefit of lime products.
I have established that there are two differing attitudes on how to deal with damp with regard to old properties.
The surveyor and timber treatments men are singing from the same hymn sheet. They verbally have said remove all existing wood from the walls/joints (and recommend removing the wood lintels - most not original) apply sand and cement mix combined with special chemicals to deal with the salts, and coat the walls from floor to ceiling. They are then saying Vandex about 2 foot high, all the walls. Then apply thermo board to the external walls (directly) and I think dry line the internal walls.
With regard to the floor, break up the cement floor dig, put in damp proof course and 4 inches of concrete and batten. Batten to reuse the existing wide floor planks.
The lime chaps says just apply lime directly to the walls but possibly if I want wood floors it is a still worth puting in a damp proof course in the floor.
I realise the difference in the two is one is trying to stop the damp/condensation and one is allowing it to pass through the property. It seems to make sense to me to do a method which is more in keeping with the age of the building and not to fight the natural elements and push the problems else where.
However I am concerned about the warmth of the house. As part of the works I am putting in central heating. The house is quite cold due to the way it faces I think and I had wanted wanting decent insulation to retain the heat. I realise you can use hemp with Lime but is there any thing else comparable with thermoboard?
Assuming I do put a damp proof course in the floor and rely on just lime plaster on the walls Should I do anything else to deal with damp (rising damp). In one room I was going to put some wood panelling up to hip level for example.
Would the method recommended by the surveyor and damp treatment man most likely lead to other problems?
If I put new oak lintels in and use lime plaster on walls should I still treat all the woodwork?
It also bothers me that the lime plaster method is not the conventional method recommended by the surveyors meaning it effects the value of the house ultimately, although I am planning to live in it and not sell.
The antique bronze electrical sockets and switches I have purchased from Forbes and Lomax need 45mm deep boxes. That is another possible problems in just applying lime to the walls with less depth to play with.
I would appreciate any advice on this matter.
Alex
Alex
