Some brands do…. In practice it doesn’t seem to make much differenceI'm not aware that they have two different sides. Could it be that the second hand ones that you are working with have simply been bleached or darkened by the sun?
Agreed, the last one I did I got half way up the wall before realising I had the slightly softer side facing me. I think the key is making sure you use the mesh to provide the tensile strength.Some brands do…. In practice it doesn’t seem to make much difference
If you use a 35mm backbox then you've only got 35mm extra of insulation to get through to reach the wall, so long screws and plugs should do it. At least then you're not making a massive thermal bridge with no insulation behind at all.No problem with not having an air gap surrounding the backbox. But even if you cut the woodfibre snug to the box, I think you may still have the issue that the box moves around too much and becomes loosened, or cracks the lime plaster surrounding the socket when plugs are inserted and removed. The backbox really ought to be quite secure. It may be better to cut a hole all the way through the woodfibre and attach some sort of mounting block of timber or similar solidly to the wall. But I'm sure you'll figure it out as you go along.
No, lime plaster does not count as insulation. Also, I'd recommend using deeper back boxes than the standard 25mm ones, given that you have the depth. Many decorative faceplates or sockets with USB etc require a deeper back box so you might as well.
I used those bits but their ease of going in will depend on the stone - our walls at our old place were white lias with quite a high iron ore content in places, took a reasonable amount of effort even with a hefty blue Bosch SDS behind it, going through concrete was a breeze in comparison.It says it has on here. Stuck some on with lighter side to plaster so done now.
The real issue im having is drilling into the bloody wall. Ive got a hammer drill and these View attachment 15765
I would have throught this would have been fine, but been a nightmare. What did everybody use?
Gonna ask a really stupid question here but which side do you plaster on. Its says light side is sanded, but the light side is fluffy (technical I know). Where as the dark side is more solid and looks sanded
