pattiw1950
Point taken.
worms said:I'm not sure we should be too hasty in ruling out heat recovery/air circulation/dehumidifier technology
(although I think taking the air from the loft rather than outside is a bit daft!).
Our windows will do that without being left open!Nemesis said:I find leaving the bathroom window slightly open at the sash gives enough air to prevent or very quickly remove condensation
Nemesis said:Seems to me though that this sort of unit isn't removing moisture from the air - it's simply moving it around a bit. Maybe there could be other ways of controlling or removing moisture if it really is so bad - I find leaving the bathroom window slightly open at the sash gives enough air to prevent or very quickly remove condensation on windows, for example, without draughts. It's what they are designed to do, which many don't seem to realise.
And this device seems to be causing draughts of course - which means it needs to be switched off, which possibly negates the point of it.
Another cause of draughts which many don't consider is a fire or stove, which has to draw in air from somewhere. A vent placed near to the fire is one method of stopping draughts.
You have found the solution to condensation in your sitting room and I have no doubt that it is the solution for your other rooms too.wyseass said:i was going to ask about "heat exchange ventilation systems" as an answer to condensation problems. What is meant to happen is that it sucks up air and takes the moisture out while also releasing warm air back into the house just like a massive de-humidifier, the whole concept fasinates me as we have a condensation problem. With mould appearing in the corners of the living room. I am hoping that this is caused by the cement render inside keeping the walls really cold, therefore allowing moisture to be released from the warmer air. I do know that in the sitting room where the cement has been removed we don't have the problem any more.
