88v8
- Glorious Gloucs
Our windows are all single glazed, lead lights.
Each is different, so I'm having to devise different solutions in making secondary glazing to stop the condensation with which we're plagued. Even now, with the rh around 45% - low, for our cottage - some of the windows are running with water in the mornings. Earlier in the winter, before the woodburners had dried the house, the rh was >60% and the windows were like little Niagras.
I finished my first window last week, a fixed casement in the dressing room, using a secondary woodframed panel glazed with glass and sealed against the frame with expanding foam tape.
Before fitting, I dried with paper tissues and a hair dryer.
However, from the first day, there was slight condensation in there, and as I write all the windows in the house are clear... except the one with secondary glazing :shock: which has condensation in it. Enough that it's beginning to run down the glass, which is exactly what I was trying to prevent. It seems that water vapour is getting in, but can't get out.
Here
http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=4958
it's suggested that the original window needs to be vented to the outside. If it's not an opener - it's not - this would necessitate drilling holes.
However, the participants in that discussion can't agree amongst themselves.
Years ago, I fitted some secondary glazing in our previous house, it was not particularly well sealed but never had this problem. However, that was a relatively modern house, centrally heated and not damp.
Has anyone here any experience of this problem, and any solutions?
Ivor
Here
Ivor
