tobydog
- South Suffolk
Well, I finally managed to get to the previously unseen gable ends of my roof in the loft this weekend. New loft hatches helped!!
Although the main part of the roof was replaced in 1987, the ends of the roof still retain the original timbers. As I mentioned before, the loft is quite small because to the vaulted ceilings, however, I was very pleased to see that the end walls are actually lime render on battens. This probably explains why the roof retains no heat despite the thatch because the wall sections are no doubt quite thin. Where the lime has been applied it's broken a few of the battens, but the odd thing is that it's come through looking as though it's gone through wire mesh. The is good news because it's possible that it was applied during the renovation in 87. I really hope the builder didn't apply cement on top of old lime because we do have some cement on the front section.
There are loads of wires in the roof because all the sockets are fed from up there. I know from earlier responses that you shouldn't really cover the wires with insulation, however, does this apply to all wiring? The reason I ask is that I can see what are clearly wires for sockets and light switches (low consumption) and the feed to the electric shower (high consumption). Some of the cables are a bit tight against the joists but the shower one isn't. Can I safely let some of the tight low comsumption wires lie under the second coat of insulation or is this a bad idea, especially with thatch?
