88v8
- Glorious Gloucs
overlander matt said:Talking about the end, we are wondering about the most suitable method of supporting the flue at the chimney end. The flue was supplied with a support bracket that clamps on the flue and can be supported by the brickwork of the chimney but it looks a bit flimsy and I will most likely beef this up (not with a blue rope though). The suppliers recommended a metal plate to seal the top of the flue. I would have thought this was counterproductive from the ventilation perspective.
The insulated flue is 11m long and the uninsulated is 8m. I noted Feltwell's comment about providing an additional support lower down the flue. The insulated flue feels pretty well supported but the uninsulated one is just dangling!
Another decision is needed on the cowls. I have 5 flues that are unused and need a ventilation cowl and 4 with liners. The octagonal shape of the pot complicates this - the internal diameter at the top is 225mm and the external is 275mm but the round profile of the chimney only extends for 30mm from the top before it takes on its octagonal shape which doesn't allow much for the cowl supports to be strapped on with the long Jubilee clip.
As I may have mentioned, I used the Brewer UFO2.
To attach it to our very similar octagonal pot I used stainless wire, ran a loop around the top of the pot under the lip and wired the cowl to the loop. It ain't going anywhere.
Long runs of loose liner aren't a great idea. Especially now that sweeps tend to use a power sweeper which can make the liner move around a lot. So Feltwell's point about an interim support is a good one.
It's customary to close the top of the flue with a plate, also helps to support the clamp. That insulated liner is heavy and it will be supported mainly from the top.
But yes, it's counterproductive from the ventilation perspective.
So, to give continued ventilation in the flue, I drilled four x 1" holes through the stack near the top, and covered them with stainless bee mesh. Then at the bottom I have a slot about an inch wide along the back of the register plate, so there is a constant through flow of air in the stack.
That has worked well in drying what was a wet stack, so wet that in bad weather we had pools of water in the fireplace where rain was getting in through defective pointing somewhere under the thatch. And no doubt is still getting in, but the ventilation nullifies the problem.
Ivor
