jmbarker
- Huddersfield, West Yorkshire
Dear all,
My predicament is explained in the letter written to the person responsible for such matters at the council - no response.
Any advice on whether my thoughts are correct, will be welcomed.
____________________________________________________________
Dear Mr [ ],
I am e-mailing you in relation to the Building, which my family and I moved into in March 2006. We purchased the Building from Mr [ ], a person I suspect that my have entered into correspondence with you similar terms.
If you aren't already aware, the Building is Grade II listed.
Immediately in front of the Building (approximately 0.25 metres from its curtilage) is a bus stop/shelter ("Bus Shelter"). This Bus Shelter serves amongst other bus services, the number [ ] operated by First.
I understand from the previous owner that the Bus Shelter was moved immediately in front of the Building in the last couple of years.
Was appropriate planning permission and listed building consent obtained to erect this Bus Shelter, given its proximity and line of sight to a Grade II listed property?
I ask this question with reference to the document headed 'Planning Services, Listed Buildings' available for download from http://www.kirklees.gov.uk/business/planning/advicenotes/ListedBuildings.pdf. The text under 'Heading 8' provides that:
- "Setting may be affected by proposals for free-standing buildings within garden ground, alterations to walls or approaches, sight lines to or from a listed building";
- "In these instances, permission may be required";
- "Any proposal that will adversely affect the setting of a listed building will not be granted";
- "Where a listed building forms an important visual element in the street, the Council would regard any development in the street as being within the setting of the building".
There can be no doubt that the Building does form an important visual element of the locality. It is one of the oldest buildings in the area (built circa 1727) in a central location throughout which most [ ] residents will see and pass, particularly those attending the village store.
Given the proximity of the Bus Stop from the Property (0.25m from its curtilage), there can be no doubt that this erection is within the setting of the the Building. In addition and using language which is applied in so many decision notices applicable to the the [ ] area, the Bus Shelter, 'has an unsympathetic and incongruous form, which detracts unduly from the Building having an adverse effect upon its visual amenity'.
It may be worth your attending the location, as you will see the graffiti which is scratched into the Shelter as well as the rubbish left by school children. This is not insignificant and again impacts on the visual elements of the Property, as do the single and double decker busses which park at the Bus Shelter daily.
end.....
Dear Mr [ ],
end.....
