tobydog
- South Suffolk
In my defence I was referring to a thin application of emulsion and it all goes horribly wrong when you have multiple layers and finishes plus lining paper and who knows what.
There is a bit of a difference between the slow long term evaporation of moisture through a wall and it's coverings, and the steam blasting you tried to apply. It all comes down to resistivity, time and distance. All materials have resistivity to vapour movement through it and this is measured by how long it takes to travel a certain distance over a certain period of time. There is an argument that vapour could travel through 10mm of cement quicker than it would through 50mm of hydraulic lime. Whilst the vapour would move quicker through the lime due to its lower resistivity it has further to travel.
With paint, although we are only talking in microns, the resistivity varies by product and therefore, given the same thickness, the vapour (steam) would have got through eventually given enough time. It's all relative.
Clearly there are some products used, for example, in tanking procedures where the resistivity is so high that it's almost incalculable.
