You have made a very good and valid point Penners, in order to minimise thickness" intrusion" on the existing elevations of the building and therefore avoid interference with roof eaves.Penners said:Middi - if there isn't enough roof overhang for Zebra to follow your original plan, wouldn't it be possible for the insulation to be inserted between the studs? A breathable membrane could then be applied to the outside of the studs, then battens, then stainless EML and lime render.
Would that work?
Another possible solution that would work quite well, although a little less efficient, is to insert the insulation between the wall studs, as you suggested. As long as there is an existing void and not all those wattle and daub panels. These could be sealed if loose within the studs by stuffing wool between studs and panel.
Once this has been done, be it with rigid insulation ( ie celotex or similar), sheeps wool, rockwool or one of those multilayered insulation blankets, it would be wise to add structural plywood ( or engineered stirling board) on the outside of the studs in order to strengthen and stabilise lateral movement os studs. Above this plywood I would fix the battens and then the breatheable membrane. The reason for this would be to create an air gap between the ply and paper and therefore freedom of air circulation eliminating the membrane to be in close contact with the ply as this would render the function of the breatheability factor useless.
One has to assume that water vapour will permeate to a certain extent through the paper/membrane and as long as there is a reasonable air gap beyond the entry point and behind the membrane then there will not a problem. This arrangement would work quite well and allows for provision of substantial insulation.
If wattle and daub panels are in situ then it would be wise to use those multilayered isulation blankets on the exterior of studs in order to preserve them. Ply panels, battens and membrane to be used as above.
Middi
