elm
- West Wales
My partners work rather than my own I must confess .....Gervase said:Well Done! Bet your wrist aches, though...
Variable, but the majority is coming off in satisfying lumps so far, the remainder sounds promisingly hollow.MdB said:Did it come off easily or is it well stuck? The small amount I've done on our house has come off easily thankfully. Its great finding out what is underneath. Have you decided what you are going to do to the wall, just repoint and leave the stone exposed or are you going to plaster over it?
Seems only to have been painted in the past. Layers and layers, initially white, then various pinks and one layer of an ochre colour. Traces of many of these colours indoors too. A lot of preseli bluestone (of Stonehenge fame) used in the construction, harder than granite so probably would weather well, assume the layers of limewash would have protected the soft mortar. For the moment we're just going to let it breathe for a bit .....Nemesis said:I suspect it was never intended to be exposed - re-render in lime?
Any particular reason as to why the sharpness of the sand is important?andrew gayton said:I would suggest that you repoint in a non-hydraulic lime and (very) sharp sand mortar and re limewash.
Is there any problem with pointing in lime externally? If so, what should be used? The wall is held together with mud so exposing that isn't going to be a great idea.andrew gayton said:as for limewash on sandstone................ best not as sandstone does not like lime! hence sandstone is always used at a higher level than limestone to prevent damaging water run off................ saying that, you will find 'historic' examples contrary yo this advice.
looks like that doorway was once much wider...............?
Agreed, there is a sense of relief in the air as it emerges .....andrew gayton said:the building looks like it is awakening from a long period of hibernation
Definitely - on the inside downstairs there is still a huge beam across the original span of the cartshed door.Nemesis said:Cartshed, hayloft above?
Yes, it certainly will. There is a wooden lintel visible inside on the upper floor, so will be fascinating to see what is revealed - more of it coming off tomorrow, weather permitting .....Nemesis said:Will be interesting to see what else is revealed when the rest of the stuff comes off.
Yes the fad is recent but I don't see any problem in it. Limewash can always be added at a later date so why not enjoy the building the way the owner wants to enjoy it? The house is a home and not a museum piece. Each new owner adds something of their taste to the building (as can be seen in the white, pink, ochre and cement(!) layers of this house). Why should not the current owner do the same? Bare stone is just as valid as limewash in my book if that is what the owner wants.Nemesis said:The fad for exposure is recent, and IMHO not a fashion to be followed lightly. Welsh vernacular rubble buildings were usually covered with wash or render and wash. Leaving them naked isn't considered the done thing by the cognoscenti...
http://periodproperty.co.uk/forum/viewtopic.php?f=1&t=8905&p=99740&hilit=Welsh+Vernacular#p99740
