because i think i have found one.
my inglenook was encased in wire mesh and cement render , i stripped all this off to find a sodden brick inglenook behind , it also had a dpc under a cement hearth that was also wringing wet.
anyhow , to the side of the inglenook on the inside there is an arch , its made from modern plaster. on the other side where i removed the wire mesh and cement i found a much bigger hole. at first i thought it was where the bricks had been damaged but then i noticed it to have a constant shape.
its a large arch with a smaller arch inside , the single skin brick inner arch has two diagonal bricks that seem to be acting as a lintel.
now all that is left is a skim of modern cement in-between both sides and i wont remove this until i am sure it wont damage anything.
as you can see i have drilled a hole in it to mark out where the top of the arch is.
there also seems to be an old brick window ledge in the other side of the ingle nook where the same arch has been made from modern cement.View attachment 2
this is the arch from the inside of the cupboard. you can see where i drilled the marker hole.
and this is it from the inside of the fire place. note the modern cement arch.
