Matt Green
Toby Newell said:And... actually uv light doesnt really knacker wood, trees seem to quite like it.
Trees have bark too.
My old university deptartment did some work on this:
UV pine – the way forward in wood colouring UV pine is jointly funded by the wood industries and the European Union under the CRAFT programme, to the tune of C300,000. It brings together seven companies and three research institutions from Ireland, Germany, Spain and the UK.
The researchers involved from BCUC include Sharon Grover and Prof Hew Reid (Design) and Dr Andy Pitman (Forest Products Research Centre, Technology). The project stems from the desire of the European Union to reduce emission of volatile organic compounds (VOCs) including those used for finishing furniture, since they have a negative impact on the environment. However these finishes serve an important purpose in colouring and protecting the wood surface. Colouring of the wood is particularly important to softwood furniture manufacturers since newly processed softwood is bland in colour and requires staining to meet customer requirements. The scale of the problem can be appreciated when one realises that 70% of EU furniture is manufactured from softwood. In the past, softwood furniture achieved a more agreeable colour on ageing as a result of exposure to light. However, the requirement for rapid throughput in furniture processing means ‘natural ageing’ is not an option. This project therefore aims to achieve accelerated surface colouration through the use of UV light.
One of the partners, Honle, a world leader in UV technology has supplied apparatus emitting a range of UV wavelengths. This will be used to determine the optimum range of wavelengths required to bring about colour change in three softwood species used by EU furniture and flooring makers namely Scots pine (European redwood), pitch pine and radiata pine. BCUC researchers have sourced these species and are currently processing the test samples. Preliminary work has been undertaken to determine the wavelengths and exposure times necessary to bring about the required change. These experiments have shown that the process works and so the project will move on to the next stage, i.e. optimisation. As well as colouring the surface, UV exposure has been reported to harden the wood surface. This is also being investigated at BCUC with the assistance of Dr Hugh Mansfield-Williams of the Forest Products Research Centre. This hardening will lead to the additional benefit of scratch resistance in flooring and furniture, another important property. Although the project is in its early stages, initial results are promising. Dr Pitman reports ‘it is admirable that cross faculty research can be conducted on a problem relevant to all EU furniture manufacturers. Ultimately any process which benefits the environment will be of
benefit to all EU citizens’.
All very admirable stuff, although the reverse is likely to be true in this case, the purpose is to inhibit the impact of UV light on the wood. Seems a reasonable aesthetic concern though.
Matt.
