DJH
- Co Tipperary Ireland
Mike...BTW????? :shock:  :shock:
Doug
			Doug
MikeG said:Flyfisher said:Thanks for that clarification. So presumably a 'secondary means of escape' could simply be a door to another room?
No, to the outside.
DJH said:Mike...BTW????? :shock: :shock:
Doug
MikeG said:JanieB said:.......One beautiful Georgian house had had a single-skinned, corrugated roofed single storey shed added to it prior to listing. This eyesore of an extension was therefore part of the listing and the owner fought for years to be able to pull it down.
At the moment, if they listed my cottage, or included it in the conservation area, I would be either stuck with the horrors perpetrated on it in 1981 or have a long fight to undo the damage.
I don't know why this is such a generally held view. I am doing changes to Listed Buildings all the time, and the process is very straightforward. I suggest that people always employ an architect (with a background in conservation work) ...........well I would, wouldn't I?!.........because they'll design the right extension and alterations and get it through without any great hassle 9 times out of 10. I've never know of "years of a fight", nor have I known anyone stuck with an unwanted modern extension to a Listed Building.
malcolm said:MikeG said:Flyfisher said:Thanks for that clarification. So presumably a 'secondary means of escape' could simply be a door to another room?
No, to the outside.
Doors to other rooms which have means of escape to outside work too, so long as you can get to the other room without using the corridor which is up in flames at the time. All they want is a second means of escape should the obvious route be on fire.
