Nemesis
- Planet Earth
I think, in a slightly muddied manner, the point is being made that energy use can be reduced in ways which don't involve DG.
Penners said:Hmmm - are you sure?skier-hughes said:Low energy bulbs produce less heat, thus less heat to lose.....![]()
If your house is centrally heated, then it will almost certainly have a thermostat that cuts out the boiler when the house has reached your chosen temperature.
The thermostat isn't fussy about where the heat comes from - radiators, light bulbs... only that the chosen temperature is reached.
So if your light bulbs give off less heat, your boiler needs to give off more heat.
No, not very much. It's summertime!skier-hughes said:And you don't put your lights on when you don't need your boiler on?
Mercury is released into the atmosphere from coal power stations with the flue gas. Somebody told me that the amount of mercury in the light bulbs is less than the amount released in the smoke from generating the electricity that would have been needed if one hadn't changed one's light bulbs.Flyfisher said:mercury content.
