Lime
- East of England
A couple of observations re- the manhole.
1. From what I can see it would be possible to remove two courses of bricks to lower the cover.
Obviously the removal of the bricks must not damage the internal structure.
2. The two pipes in the picture, one orange one grey, have been added to the system.
I presume the orange pipe serves a drain with a water seal trap?
The grey pipe appears it may be a rainwater pipe and I doubt that it has a water seal.
This will allow foul air to escape from the drain in and around the house.
Perhaps more important, the brickwork that surrounds these two pipes has not been finished off properly.
If the sewer becomes blocked or floods, the hole around the pipes will allow sewage to escape into the surrounding soil and add to your problems of damp.
Also both pipes do not connect to the manhole correctly.
They should be designed to enter the lower channel in the line of flow without splash and turbulance.
It is possible that cracks may be evident in the lower area (out of shot) and sewage could leaking into the surroundings all the time.
If the lower channel (where the sewage flows through) is not plastic there is a high probability that the earthenware pipes are cracked (because they are so shallow in the ground) and leaking particularly where each pipe joins another.
