plasticpigeon
- Birmingham
I am totally convinced that cement pointing ruins old brickwork as I have observed so much damaged and spalled old brickwork where it has been pointed in cement. The reason normally cited for this is that lime pointing allows moisture evaporation out of the bricks. I've always thought this sounds a bit unlikely. I'm sure there are times when there is a freeze after a heavy rainfall without enough time for evaporation in between to make a difference. It seems more likely to me that water can get between the brick and the mortar, and when it freezes and expands, it damages the brick if the mortar is harder than the brick. What do others think.
