Clockmaster
MikeG said:OK, never mind. I've re-read the thread, and the focus switched half way through the first page. I'm still interested in something more definitive about the white cottage.
So am I MikeG. Inside, the room with the larger window contains the front door, along with the staircase, which has been taken out and replaced in what looks to be a 1960s bannister affair, you know the type, two wide slats the stretch of the staircase. This has been moved to nearly touching the inside of the front door, which has been bricked up from the inside, plastered and papered over with 1960s brown and yellow wallpaper. This looks to have been done to make the sitting room larger, with the bottom part of the staircase taken away. If the carpet was removed, I'm sure the witness marks of the original staircase would be there. I believe this place retains its original front door, with no letterbox, and no evidence of there ever being one.
