You are generally correct Penners but you have missed the heat store effect of the underfloor. This means that when you light the stove and cause the room temperature to rise enough for the thermostat to switch off the underfloor, it will still be chucking out roughly the same amount of heat - at least in the short term. This means that the stove will be additional to the underfloor output rather than replacing it and the room temperature will rise accordingly. The next night / day, the underfloor will of course be on for less time to compensate for the heat produced by the stove.
In our house, we have the thermostat set to 20 degrees (during the cheap electricity period) and currently it is easily achieving that. When we put the stove on, the temperature will rise to 21 or 22 degrees which for us is about right. Note: downstairs for us is completely open plan and a lot of heat goes upstairs also so our 4.5kW stove is never going to make a large difference in temperature as it is effectively heating the whole house. If the room was enclosed - like a standard living room, I would expect the temperature to rise far more.
