Sonyaclegg
88v8 said:Superb.
And you've done in months what takes many people years.
Perhaps a new career awaits....
I'd do no filling around that beam until ... well, until all the timber has stabilised in relation to the new heating and humidity environment. The could be a couple of years. When we had central heating we kept it no higher that 62F to avoid damage to the house.
Do you have a humidity meter in each room?
It will be interesting to see/plot the pattern across the year - ours is highest, in the high 70%s and therefore the internal wood most swollen, at the end of summer, and lowest about three weeks ago when with both woodburners lit in the evenings it touched 45%. Now, around 56% and rising.
When humidity is lowest is the time for filling, although filling cracks around any element that shrinks and swells with the seasons is liable to be rather futile.
Although it is in a way regretable to introduce modern gadgetry, you may find that there are parts of the house that will benefit from the permanent presence of a dehumidifier. We have an Ebac in the cellar, where it takes ten points off the readings and has banished the mould.
Ah, yes, the mould... if/when/where it appears will indicate where artificial dehumidification may be beneficial.
Ivor
We have had a lot of help with skilled craftsmen along the way but done as much as we can where we can. I can sand floors and seal wood but I draw the line at painting as all previous attempts have been an unmitigated disaster! We split the work between us so J was responsible for three phase electrics, septic tank, drain fields etc. He had lots of fun with diggers and the like with our two sons along with the contractors. I've dealt with all the applications, and the inside of the house.
Mould had sprung up on the inside of the mullions in the bathroom which is to be expected so a good bleach wash down keeps it in check.
I will invest in a humidity meter and see what readings I get..
