88v8
- Glorious Gloucs
discobarry said:The french drain runs at what i would call the base of the building, so in reality it is roughly 3feet underground. No water ever comes out of it into the drain which runs at the side of the house....just bits of muck sometimes. So i think it isn't doing too much.
It might be working if it was well made and has been well maintained; pipe bedded in pea shingle, wrapped in filter membrane, graded stone fill, no soil on top, mesh on the end to keep rats from nesting in there. If it's just a pipe chucked in the ground and the surface has leaves and soil in there, as you say probably not doing much.
If you run the hose on it, does water come out?
Ivor
