robgil said:MdB said:Something like the following:robgil said:i shall get you the router spec this evening , what exactly do you need to know?
Actual Data Rate
Up Stream 448 (Kbps.)
Down Stream 2400 (Kbps.)
Upstream Downstream
Noise Margin 16 dB 7 dB
Attenuation 63 dB 60 dB
More is better than less if you are unsure which are the correct figures.
how do i find them out then?
ok here goes,
data rate
up stream 448 (Kbps.)
down stream 7200 (Kbps.)
noise margin
up 5 db down 20 db
attenuation
up 13db
down --- db
i cant see an actual data rate and attenuation down is just bas shown above..
