biffvernon
- Lincolnshire
Putty lamp in action at SPAB meeting last year:
I've got a useful tile cutter with a diamond tipped blade - can glass be cut on this?
It certainly flies through porcelain and ceramic tiles.
There's one way to find out! :wink:inwood said:I've got a useful tile cutter with a diamond tipped blade - can glass be cut on this?
skier-hughes said:So is there any ideal way to cut glass.....
I bought a diamond tipped glass cutter.
I marked where I wanted to cut my glass
I dipped cutter in oil.
I made one good mark acros the glass.
I try to break it, as per instruction sheet which say to hold each side and break - fail
I put glass on wood and the bit that needs to brerak off overhangs, try to break it, can't, hit it gently with wood, won't break, whack it with wood it breaks, but goes any which way.
Try again, make a deeper cut with cutter, if I can and it still breaks anywhere it likes.
Funnily enough, if I drop the glass into the broken glass bag it splinters and breaks with much ease, but when I'm trying to break along this line it just won't go.
The glass is 24" pieces that have broken and I'm trying to tidy up for my greenhouse, instead of just going out and buying new ones. Though considering so far I have cut 11 pieces, some twice, and not got it right yet I'm going to have to buy a lot more than I hoped for.
Glass is 3mm, so not very thick.
Do you think it is just the quality of the greenhouse glass is poor and so breaks anywhere?
I don't think I should scribe the line more than once should I? As I don't expect it'll run true for a second mark.
Graham
skier-hughes said:Ok, as soon as the rain stops I'll give those ideas a go
