LadyArowana
JoceAndChris said:I can't drink mains water anymore, it makes me ill.
London would be OK, I'm sure it's gone through a few kidneys :lol:
Lindyboo said:As far as can be determined it’s a huge metal container – presumably either copper or stainless steel – about 10ft diameter and at least 10ft deep. It’s topped with a brick cupola and has an aperture in the top about 2ft dia. The bricks are very old so perhaps the metal receptacle was installed in modern times and finished with old bricks, but I’m guessing at that. The well now serves as a soakaway for the run-off from roof – the water can be heard running into it.
When/if the garden landscaping project (see my other post) gets going I want to make a feature of the well and if possible make use of it to water the garden. Anyone else got something similar and made a feature of it? And has anyone else got a metal tank installed in this way?
Onetap said:Lindyboo said:As far as can be determined it’s a huge metal container – presumably either copper or stainless steel – about 10ft diameter and at least 10ft deep. It’s topped with a brick cupola and has an aperture in the top about 2ft dia. The bricks are very old so perhaps the metal receptacle was installed in modern times and finished with old bricks, but I’m guessing at that. The well now serves as a soakaway for the run-off from roof – the water can be heard running into it.
It sounds more like a cistern, a glorified water butt, than a well. They were usually built of brick and waterproofed with puddled clay. They were used to store rain water from the roof drains.
I'd use it for irrigation, maybe look into a grey water system to reduce your consumption of metered mains water.
I'd be wary about getting into it, you can get fumes or gases accumulating inside any low-level confined space.
Onetap said:I'd be wary about getting into it, you can get fumes or gases accumulating inside any low-level confined space.
Lindyboo said:Cistern – that’s the word I was looking for and couldn’t think of when I posted. I’ve just found it marked as a well on an old map (1905) so does anyone know if metal cisterns were being installed in those days?
Lindyboo said:Sacrificial anode? Sounds a bit gory. What is it?
:shock:Jellyfire said:The other well on the map is roughly where the sceptic tank is so presumably that is lost for good
worms said::shock:Jellyfire said:The other well on the map is roughly where the sceptic tank is so presumably that is lost for good
I wouldn't want to share a water table with your house!
Convert your sceptic-tank-well to a long-drop and you could cut out the middle man!Jellyfire said:worms said::shock:Jellyfire said:The other well on the map is roughly where the sceptic tank is so presumably that is lost for good
Dont worry the soakaway conveniently leads way off into next doors garden according to the plans!
