A
Anonymous
Guest
I found that a cross grained float was particularly good. This is a wooden float with the grain of the wood running at right angles to the long axis of the float. It has more "bite" and an ordinary wooden float.
In my three coat work over both lath and brick I had less problem with the lath than the brick, which had much more suction. One section on brick failed to ahere properly at the first attempt, but the second attempt, using a wetter mix, was fine.
Mine is a town house which would have had quite a high standard of finish. For my second coat I used a system of dots and screeds to get the plaster reasonably level.
