FamilyWiggs
- Flintshire, N Wales.
Well, this thread has spurred me to act on our cold radiators.
We have a rather unusual radiator circuit in that it is not the traditional loop. It appears that it has been extended in a number of phases - with a couple of "spurs" added in to extend it when new parts of the house had radiators fitted. Each spur of 2 or 3 rads each is t-junctioned off the main circuit flow pipe and back onto the main return pipe (ie it is a 2-pipe system). One of the spurs comes off the main circuit before even the first rad!
I must confess at this point, one of the spurs was a quick fix by me when SWMBO declared, within 2 weeks of moving in, that divorce was imminent unless I got some heat into the kids' rooms PDQ
That quick fix is still in place 6 years later :shock:
I now have a system where only a few of the rads get hot and many are cool, or cold at the bottom - ie it seems badly balanced. This may be contributed to by the unorthodox circuit design - which also has a variety of pipe sizes from 28mm to 10mm
Given the complexity of the circuit should I:
a) spend many hours trying to balance the rads and spurs to get good temps throughout?
b) if possible make the spurs part of the loop?
c) give up, buy brandy and warm jumpers?
Robin
Robin
