Nigel Watts
- London N7
Plumbing and I just don't seem to get on.
I have often taken off radiators to decorate behind them or, most recently, to install wires for a wall mounted TV in our modern extension. Not trusting the thermostatic valves I usually put a cap on the pipe as a precaution. Since taking the radiator off the hot water system has consistently been losing prerssure - about 1.5 bars in three for four days. I have been obsessively checking for leaks.
I found it this morning. Brown damp staining in the room below (my wife's study) confirmed the location. The thermostatic valve seems not to have an off position but a "frost protection" setting, which means it comes on below 8 degrees. The room has another radiator so later in the day (when I have been checking for leaks) it switches off because it is warm. My cap, though screwed down tightly, is leaking when the valve comes on.
When plumbers install central heating systems it should be obligatory for them to leave an instruction manual. How else is one supposed to learn about such things other then expensive trial and error?
