Zebra
- St Albans, Hertfordshire
It's quite a small area, so the extra cost is not such an issue as it would be in a larger house.AMc said:I would only use thermafleece if I were rich and breathability was a concern - in my place it isn't thanks to the materials used elsewhere.
AMc said:I stuggle with idea that 50mm of wool and tri iso is going to outperform 25+50mm of kingspan/celotex/ecotherm but I could be wrong.
What U value are you quoted for the multifoil and has it been verified by BRE?
Well I was quoted U-value of 0.29 for 25+50 of celotex/kingspan, and U-value of 0.15 for 50mm of wool with Triso, but as you say, this is unverified. How would I find out from BRE for a particular build-up? That was what I was hoping to do with this software but Triso isn't on it.
AMc said:I would go with kingspan/celotex/ecotherm between the rafters and foamed into place then board at right angles with insulation backed plasterboard to minimise potential gaps (assuming your rafters are set at spacings that make that practical).
Thanks for your suggestions. What sort of foam? Expanding foam? Won't it stick to the rafters and mark them? Don't quite understand, probably being daft but - board at right angles? you mean under the rafters? In which case it doesn't matter what the spacings are?
