malcolm
& Clementine the cat
- Bedfordshire
Feltwell said:You've done a lot better than most would by the look of it! Producing mouldings without machinery like a spindle moulder is not easy, or sometimes even possible.
Blaming the tools was going to be my next strategy. The router has been great. There were some parts of the moulding it couldn't reach that I can finish with sandpaper, but it did enough.
The table saw is a nightmare because the bed isn't flat. I ended up with different height cuts along the length of the wood. It's only 1, maybe 2mm, but that results in a lot of finishing when you want to get everything inch perfect. It's a cheapo from Screwfix. Can anyone recommend a decent table saw with a flat bed before I do the big bay window?
Fitting the frame is turning out to be time consuming. The bay is curved and I'm planning to use flat glass which results in 7 degree angles everywhere you don't expect them. The horrid bit of straight glass at the end is a modern replacement for a curved crittall opener. Such a pity as I can restore those.
