JoceAndChris
- Lincolnshire
That sounds good and that is exactly what the man at Womersley's said on the telephone today. Thanks!
Feltwell said:following a recommendation on here I put this stuff up:-
http://www.lindab.co.uk/dokumenter/ARC0904_12pp rainline.pdf
It's very good, much better than plastic. I ordered it through my local Travis Perkins.
Probably the same as it does with your clothes on.FamilyWiggs said:How does it look in the flesh...?
Feltwell said:I wouldn't bother with plastic guttering personally. It's brittle, it fades, it creaks like mad when it expands and contracts (which mine did every time the sun came out or in again, literally!) and if you put a ladder against it you risk breaking it.
When replacing my roof, I put cast iron up as per the original but I have 2 dormer windows that are only accessible by spending a small fortune on scaffolding. Wanting something as maintenance free and durable as possible, following a recommendation on here I put this stuff up:-
FamilyWiggs said:Feltwell said:following a recommendation on here I put this stuff up:-
This looks very interesting Feltwell. How does it look in the flesh and what are the costs like?
johnandrew said:Thanks Feltwell. A quick glance suggests that they don't do a square section one which I want for our house which is a shame.
Feltwell said:And finally, this is what burnt sand mastic ends up looking like - next to linseed paint and lime pointing.
johnandrew said:Is that the burnt sand mastic you made yourself?
Are those normal size bricks? If so, your mastic must look very good from usual viewing distances - very neat and tidy.
