Sonyaclegg
Zebra, thank you for the link. It was amusing. To think that bark up or bark down divides a great nation!
ChrisD said:The look is definitely more 'cottagey' (some may say 'hobbity')
Sonyaclegg said:We have had a timer fitted to the boiler so it's not rampaging on 24 hrs a day. 2 hrs in the am and 2 in the pm just so the contractors on site are comfortable. The house seems to be quite good at retaining the heat; perhaps because the walls are so thick. I feel much better now that its down to £8 a day. We are having the heating placed on 6 different zones and we will be able to program it so the heat follows us around the house with our daily routines.
Joce, you are wise to keep warm whilst you are recovering. All your energy needs to go towards getting you back to full fitness, not trying to keep you warm.
DJH said:Has anyone felt a luke warm radiator somewhere when either the heating is turned off or shut down by a motorized valve?
Ah, that was Lady A, not me.Sonyaclegg said:Zebra, thank you for the link. It was amusing. To think that bark up or bark down divides a great nation!
I'm already ahead of you with the zebra print hot water bottle cover Lady A!LadyArowana said:and if you put it in one of these nobody will even know you are wearing it
Yes it is a bit late - it is all in now but fortunately we have a simple system and it sounds like it is ok. We have a single pump in the heating loop of our heat pump. It pushes the hot water about 5m into the house where it is directly distributed into the floor loops via a manifold. The return is identical. As the temperatures produced by the heat pump match that required by the floor, there is no mixer nor additional pump so all very simple. It seems to work well and now we have the extra loops in, the heat pump no longer short cycles which is good.DJH said:Yes, that's what is sounds like to me although I haven't much experience of underfloor heating systems apart from installing my own, but the flow and return from the manifolds are best taken back to the heating source directly without any other pipes connecting to them. This enables you to fit the mixing valve and the underfloor circulating pump near the boiler to help reduce short cycling of the appliance. Do you have a dedicated circulating pump for the underfloor heating circuits?
The ideal design of the system should, in my mind, has a header and footer distributors, which, in effect are large diameter pipes with tees off them for each zone and independent circuit such as the underfloor heating manifold/s.
Hope this helps but maybe too late now?
Doug
Frosted or condensation? If frosted then the ground loops aren't working very well - we have an outgoing temp of 4°C and a return of 6°C. You don't want to go much lower than that due to the dangers of freezing the fluid in the pipes which can then wreck your heat pump.DJH said:and the external pipes seemed to me to be permanently frosted
Sonyaclegg said:To think that bark up or bark down divides a great nation!
