Penners
- Suffolk, England
Water is certainly notorious for its ability to appear some distance away from its actual source. So it's well worth extending your search well beyond the immediately obvious wet patch.Balaphuel said:I'm sure water from the patched section could still find its way to this corner. Interesting comments regards the little edge & the need for good pointing above it. I'd have to be on a scaffold to check its condition though.
As for inspecting the pointing above the ledge - could you not manage some sort of view using a simple mirror on a stick?
