Or not, as the case may be :lol:inwood said:I'll come clean once someone's identified it.
I see water supply for the basin, but no waste pipe?
I see lots of plywood which will eventually go soggy around the bath and swell up, causing your tiles to pop off and making you think that you should have used a waterproof tile-backing board like as wedi or aquapanel?
Ah - I somehow didn't think your electrician would be quite that spaced out!inwood said:What are meter tails'?
