FamilyWiggs
- Flintshire, N Wales.
It is certainly worth checking that this is old movement. We had a front wall of our outbuildings that wasn't tied into the cross walls at all. This was the result:
We've had it rebuilt and tied in in two ways - firstly with concrete t-bars set into the front and cross walls as they were being rebuilt and secondly (and probably not necessary) with some helical steel bars laid in as well. There is no longer a void in the wall, and so I'm reasonably confident that this will now outlive the grandkids.
One thing I was persuaded on but still have slight doubts. Our mason (well respected and carefully chosen, does work for NT, Heretics, CADW, etc) was not happy once we'd cleared the footings and dug a bit into the clay just to relay the wall in the existing footings. We excavated further and poured in some concrete, and then built the wall on that. Normally I'd have been fine with that - but we weren't rebuilding the whole front wall, so I have some misgivings that the building may pivot in future as there are differences in the footings.
However the original building has been there for 2-300 years, so I'm reasonably comfortable it has settled. I just hope the grandkids don't curse me if they have a large crack open up.
Apologies for useing the word concrete twice (now thrice!) in a post
... but I'm a firm believer that all building materials and approaches can have their appropriate place in a project - with the obvious exception of expanding foam! Mind you, even that I suppose has its use in window installation?
