MatthewC
- Central/South England
Hi DamonDamon said:Thanks for the replies everyone. I think I'll use a hair and lime putty mix to repair the ceiling.
If you are doing it yourself, I hope you have strong arms! I found it really tiring as you push the first coat of mortar through the laths. NB Make sure that the gaps are clear as that nib is crucial to the strength of the finished ceiling. Also, you don't want to go walking about up above for some weeks until it has dried. The first coat (I used Mike Wye 3:1 haired mortar) is about one cm thick and is scratched to make the base for the subsequent coats - it all hangs on the nibs. The second coat (also 3:1) is without hair and gets a going over with a wooden float to smooth it (hence "float coat") and to make a rougher finish for the third coat (only a few mm) for which I used 2:1 plaster from Mike Wye. My final coat was Regency plaster as I wanted a fine finish, but you could stop after the third coat.
NB I used ready mixed plaster in order to take one variable out of the mix!
As regards dampness generally, it can take literally years for the place to dry out entirely - it's liveable after a few months but the process continues for ages
Matthew
