robgil said:among other things on my survey saturated brick plinths on internal and external walls. its a timber framed building.
could this be caused by concrete floors? i also suspect concrete/cement render may not be helping very much.
any thoughts?
robgil said:i am concerned about the cement floors inside because i dont really want to be lifting them up before i have some reclaimed bricks to put in their place.
and judging by some of the quotes for the roof repair we wont have enough money left over for very much so i am trying to prioritise cash expenditure for the things that really need to be done , such as the roof.
Almost certainly. Ground moisture is unable to permeate through the concrete, so it migrates sideways and ends up soaking into the plinth. If there is cement rendering on the plinth, then that will, of course, trap the moisture inside it.robgil said:saturated brick plinths ...could this be caused by concrete floors?
Oh I don't know, you get used to it after a while:CHRIS said:A building on Acro props is a sight and not for the faint hearted
robgil said:i think i need to pull the concrete floors up and put down something else.
if there is a porous floor down and no dpc whats to stop the humidity levels in the house becoming problematic?
Southern nancy....Flyfisher said:no more need for buckets in the bedrooms when it rains.
Penners said:Southern nancy....Flyfisher said:no more need for buckets in the bedrooms when it rains.
Penners said:Anyway, I happen to know that FF is actually a Hertforshire man, masquerading as ruffty-tuffty Norfolkian.
AMc said:If the roof is watertight you may find you have plenty of time to work on other things before you can get a thatcher to come and spend your money.
A tale told in the shops and pubs - a local GII house was bought and needed rethatching - the new developer/owner got a thatcher out to quote. Job was £25K or something horrific, owner agreed and asked when could they start? Two years was the reply. How much to start tomorrow? The answer was double, as he was financing the house to resell and couldn't start before the house was water tight he paid - presumably bumping every other client back 3 months. Having viewed the house I can believe it to be true. For all his expense the house is currently let, having failed to sell for over a year.
.robgil said:AMc said:the earliest is this fall.i
