charlie-ia
- LANCASHIRE
The wooden floor of the upstairs of our barn has completely collapsed at one end, and is thoroughly rotten at the other. how do we safely remove it?
Theres no way it can be walked on, and several feet deep in junk and muck, (including various toxic looking farm related glass bottles with dubious liqiuds, and heavy sharp rusty metal stuff.) I'd ideally like to remove all this before tackling the wood itself, but dont see how to get to it.
despite touching the ground at one end, the floor is almost complete, so you can walk under it, but cant see through except a small area at the low end.
I dont think the floor would hold my weight, even with a ladder or something to spread the it out.
if you use pitprops, do you just extend them so the beams cant move, or do you try to take a bit of the weight off? i dont suppose that forcing them straight is a good idea. are they what we need, or is there something else?
is it better to work from above or below? and how do we go about it without falling through or dropping half a tractor on our head?
