A
Anonymous
Guest
Many thanks for your suggestions, and especially for also saying that you don't have direct experience. On reading through this forum I have a suspicion that some other contributors are not quite so candid!?!?
Do you think a Strong Boy is the right tool? I've never used one, but this site (http://www.higear.co.uk/hire/products/buid.htm) says that it is used for inserting into a mortar course so that masonry beneath can be removed. Or am I missing the point of your suggestion?
I think the issue is that in a single pitched roof the downward force of the weight of the roof exerts an outward force on the rafter ends, which the joist between them ties together (i.e. in tension) as well as providing the structure for fixing a ceiling and/or floor to. If you cut through the joist or rafter this strong triangular structure is no longer complete. So the question is how to support it until the repair is complete. As far as I can understand supporting the joist is a matter of using a vertical prop beneath, but what are the accepted methods for stopping the outward force on the rafter? Or does it not matter if you only repair one at a time?
If #51 is reading this, I would be very grateful if you could give me the benefit of your experience. I would like to hear all the ideas and then decide how to proceed. If it is of interest I will let the forum know how it went in the end, including a photo of the hopefully successful repair.
