Feltwell
- Shropshire, England
AMc said:Certainly when I was up the scaffold I had to keep reminding myself not to walk backwards etc.
Yes, stepping back to admire your handywork is not a great idea!
I have worked at height with a harness on (essential in my case - I was on a partially completed bridge about 80' over the M62, trucks whizzing past below as I walked out on the bridge beams, no bridge deck in place yet!) and they are very restrictive. There's no way you'd get a "normal" roofer to wear one. There is always a risk to working at height, but with proper scaffolding on a roofing job the risk should be limited to you rolling down the roof slope and smacking into the scaffolding at eaves level, if proper toe boards and handrails are in place.
Be scared of the ground, not heights. It's the ground that hurts you. :wink:
