Flyfisher
- Norfolk, UK
I'm considering dealing with a large roof that is leaking in places. The roof is steeply pitched with Norfolk pan-tiles with reed and plaster (lime presumably) in-fill between the beams, much of which has fallen down over the years leaving the attic space very cold and draughty. Estimates for completely refurbishing the roof, including felting, insulation etc, are horrendous (6 figures).
I read a comment somewhere on PPUK that an attic can never have enough ventilation (a commodity this house has in spades!) so I'm now wondering if it is really necessary to go to the huge expense of virtually re-roofing the entire house or whether to consider simply re-fixing the existing tiles and leaving the attic as it is.
Of course, the roof construction doesn't meet current building regs but I understand this doesn't matter as the house is GII+ anyway. What I clearly must do is to fix the leaks and prevent further water ingress, but is it really necessary to do anything else to 'improve' the roof construction at the same time?
It certainly needs some TLC but as it has survived for over 400 years and the timbers are in pretty good condition, does it really need the benefit of being brought up to date? And whether it does or not, what are the regulatory issues involved?
