Feltwell
- Shropshire, England
MdB said:My answer would be no, there should be an air gap under the felt.
In my loft, I've used some 50mm celotex bolted to the rafters to act as a solid surface with an air gap behind it and then filled the inside with rockwool which can be jammed up tight to the celotex.
If you use solid foam insulation between rafters, then there should be an air gap above the insulation (can't remember how big - at least 30mm I think) in which the breathable roofing membrane (modern replacement for felt) is draped. The idea is that the membrane should not be stretched taught across the roof, it should be allowed to "sag" in between the rafters into this gap so that there is no possibility of water getting trapped behind the roofing battens.
But - if you use "counter battens" on top of your rafters before putting the main battens on, you can completely fill the rafter depth with insulation - as the counter battens provide enough gap to ensure that water cannot get trapped behind the main battens. Downside is it raises your roof by about an inch, which is why I couldn't do this (roof needs to tie in with neighbours as the house is semi-detached).
There are other ways of doing it as well, especially if you use sarking.
A picture speaks a thousand words, this guide is quite useful
http://www.proctorgroup.com/index.asp?lm=268
If you are insulating an existing roof which has non-breathable felt then my understanding is that you must always leave a ventilated gap between the insulation and the underside of the felt. If I was putting insulation in like this I'd put in some vent tiles to ensure ventilation to this void and stop any chance of condensation forming. There are lots of vent tiles available, but someone on here ages ago posted up one type that sat beneath existing tiles and was almost invisible from the outside? Can't remember what it was called!
