DJH
- Co Tipperary Ireland
You could try slipping some PVC guttering inside the cast iron as a temporary measure even permanently if it will cope with the discharge from the roof.
Doug
Doug
MatthewC said:From my limited experience, there were a couple of things that the Victorians were not good at. One was underfloor ventilation (often non-existent or woefully inadequate) and another was guttering: the ogee on my house had no hope of ever coping with the amount of water from a good-size roof, and the holes on the back of the ogee guaranteed that the fascia would rot. I'll bet that the existing ogee is in far worse condition than you expect. So, when you come to replace this, make sure that your new guttering is adequate - I fitted 5" half round instead of 4.5" ogee and this (coupled with 3" downpipes) gave a huge increase to the capacity. I suggest a good look during some heavy rain this winter!
By the way, is the roof itself OK?
